Ga door naar hoofdinhoud
Asus Transformer Pad Infinity Glass Replacement
Wat je nodig hebt
  1. Asus Transformer Pad Infinity Glass Replacement, Glass: stap 1, afbeelding 1 van 3 Asus Transformer Pad Infinity Glass Replacement, Glass: stap 1, afbeelding 2 van 3 Asus Transformer Pad Infinity Glass Replacement, Glass: stap 1, afbeelding 3 van 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus Transformer Pad Infinity Glass Replacement: stap 2, afbeelding 1 van 1
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
    Vraag FixBot
    Voeg opmerking toe
  3. Asus Transformer Pad Infinity Glass Replacement: stap 3, afbeelding 1 van 1
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
    Vraag FixBot
    Voeg opmerking toe
  4. Asus Transformer Pad Infinity Glass Replacement: stap 4, afbeelding 1 van 1
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus Transformer Pad Infinity Glass Replacement: stap 5, afbeelding 1 van 1
    • Once removed, replace the glass screen back onto the LCD display.
    • The new screen may or may not have new adhesive depending on where you got it. If it doesn’t, make sure you secure it with the screws safely.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Allison Poh
549 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 1,129
