Inleiding
Follow this guide if you need to replace the touchpad of your Asus Transformer Book T100TAF laptop.
The touchpad operates as the mouse for your laptop using your fingers as the cursor. It is also sometimes called a trackpad. If your touchpad is not reading your touch or when you use it, the cursor keeps jumping around on the screen and you've determined that it doesn't just need an update, use this guide to replace your touchpad.
Before beginning this repair turn off your Asus Transformer Book T100TAF and unplug your laptop from the power adapter.
Wat je nodig hebt
Detach the keyboard from the screen by depressing the silver button on the hinge and pulling upwards on the tablet.
Flip up the tab on the white ribbon cable labeled “MB” using the metal spudger and then pull the white ribbon cable away from the motherboard.
Use a spudger to carefully flip up the black tab on the ZIF connector and pull the black striped ribbon cable away from the motherboard.
Use a Phillips #00 screwdriver to remove the three black 2.0 mm screws from the track pad.
Lift the touchpad away from the keyboard assembly by pulling from the top edge.
