Ga door naar hoofdinhoud
Asus ROG Strix GL702VS LCD Screen (Display) Replacement
Wat je nodig hebt
  1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): stap 1, afbeelding 1 van 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): stap 1, afbeelding 2 van 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): stap 1, afbeelding 3 van 3
    • Remove the two screw stickers at the bottom corners of the screen.
    • Remove the two 4mm JIS #0 screws beneath the stickers.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 2, afbeelding 1 van 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 2, afbeelding 2 van 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 2, afbeelding 3 van 3
    • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
    • Using an opening tool, lift up the bezel once the glue has been removed.
    • The plastic clips remain so it will have some resistance/snapping noises.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 3, afbeelding 1 van 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 3, afbeelding 2 van 2
    • Lift the plastic bezel off of the front display panel.
    • The plastic bezel will click when put back on the screen.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 4, afbeelding 1 van 1
    • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 5, afbeelding 1 van 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 5, afbeelding 2 van 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 5, afbeelding 3 van 3
    • Once the LCD display is freed you can lift it up out of the casing.
    • Be careful as the cable remains attached.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 6, afbeelding 1 van 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
    • Once fully disconnected, remove the LCD and replace it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 46
Altijd: 2,339
