Inleiding
Use this guide to repair or replace a dead or worn out battery in an Asus ROG G751JL.
Wat je nodig hebt
Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
Pry the door up to release the clips closest to the pick.
Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
Remove the 5.2 mm Phillips #00 screw securing the optical drive.
Use the point of a spudger to pry out eleven rubber plugs covering the screws on the bottom of the laptop.
Flip the laptop right-side up.
Use an opening pick to pry the left and right edges of the battery cover away from the laptop enough that you can grip the cover with your fingers.
Pull the speaker connectors straight away from each other to disconnect the speaker cable.
Open the laptop's display to a 90° angle.
Use a spudger to pry against one of the screw tabs on the back of the upper case assembly.
Repeat this procedure with the other tab.
Use the tip of a spudger to flip up the small locking flap of the keyboard backlight cable ZIF connector.
Gently pull the cable out of its socket.
Pull the battery cable away from the connector in the same direction as the individual wires are running to disconnect the battery.
Grab the black tape attached to the display cable and pull straight up to disconnect the display cable.
33 andere personen hebben deze handleiding voltooid.
14 opmerkingen
A few steps in this guide are in the wrong order. Could get confusing for and unexperienced technician. Steps 10 - 12 should be before step 6. Other than that this was a very good guide.
Good catch! This guide was made by combining a few other guides ( we call prerequisite guides) and they were combined in the wrong order. I went ahead and fixed it. Thanks for the feedback!
This guide skips a very important step, without which the laptop is unable to connect to wifi networks at any reasonable range. You must reconnect the two cables on the left side of the monitor to the wifi chip. These must be in the order of white toward the monitor, black away from the monitor. I have taken pictures I would be happy to share for this step. Please contact me so I can share these pictures to remedy this oversight
Still not added,! Also the removal of three tiny screws under the lip of the CD Bay is completely unnecessary and they are very very difficult to put back in.
If you don't remove the three tiny screws on the edge of the CD bay, you won't be able to remove the upper case assembly without damage on that side, so they are in fact necessary to remove.
