Inleiding
Use this guide to replace or upgrade one or both the M1 and M2 macro buttons on your Asus ROG Ally.
Wat je nodig hebt
Completely power off your device and unplug all cables.
Gereedschap gebruikt in deze stap:FixMat$36.95
Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
Angle the pick upward and push it under the back cover.
Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
Lift the bottom edge of the back cover off the chassis to release the remaining clips.
Remove the back cover.
Use a Phillips #000 screwdriver to remove the 2.9 mm‑long screw securing each macro button (two total).
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use tweezers or your fingers to remove the springs from their screw posts.
Use the flat end of a spudger or your fingers to push in the clips securing one of the macro buttons.
Repeat the last two steps to unclip and remove the other macro button.
Één opmerking
One of the screws got damaged, i do not know how its it called or how i can find it. If you have that information I would appreciate it.
