Ga door naar hoofdinhoud
Asus Q500A RAM Replacement
Wat je nodig hebt
    1. Asus Q500A RAM Replacement, RAM: stap 1, afbeelding 1 van 2 Asus Q500A RAM Replacement, RAM: stap 1, afbeelding 2 van 2
      • Flip device upside-down.
      • Remove back-plate by unscrewing the two screws on either side of the back-plate.
      • Remove the plastic cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus Q500A RAM Replacement: stap 2, afbeelding 1 van 1
      • Depending on the model of the device, there will either be one or two sticks of ram.
      • There are two metal brackets holding each ram stick in.
      • To unlock the RAM, you'll need to remove the metal brackets. To do this, carefully push out the brackets.
      Vraag FixBot
      Voeg opmerking toe
    3. Asus Q500A RAM Replacement: stap 3, afbeelding 1 van 2 Asus Q500A RAM Replacement: stap 3, afbeelding 2 van 2
      • Now simply remove the ram by pulling it out using a set of pliers to be safe and careful not to damage the ram.
      Vraag FixBot
      Voeg opmerking toe
    4. Asus Q500A RAM Replacement: stap 4, afbeelding 1 van 1
      • To insert the ram line up the ram stick and the slot.
      • Next you will have to push the ram down until it snaps into place.
      • Be careful not to do this too hard, as it can break the ram.
      • Make sure the ram is secure in its slot before moving on to the next piece of ram or replacing the back-plate.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
cameron
319 Reputatie
3 handleidingen geschreven
USF Tampa, Team 12-5, Eyestone Spring 2017 Lid van USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 1,101
