Wat je nodig hebt
Use plastic opening tool to pry off the back cover of the phone.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove the warning sticker that covers the battery plug and connecting cord.
Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
Disconnect battery connecting cord using tweezers.
7 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
