Inleiding
USB ports allow devices to be connected to each other and transfer digital data over USB cables. These ports can turn out to be damaged or worn out over time. This guide provides instructions on how to replace a damaged USB port for an Asus G75VW-BHI7N07.
It is important to note that replacing a USB port can be a delicate and dangerous procedure. It is essential to approach the repair with the utmost attention to detail and care to avoid damaging the device or harming yourself.
Wat je nodig hebt
Remove the screws around the back cover using a Phillips #1 screwdriver.
Take the back cover off using the opening tool.
Carefully lift the motherboard up using the opening tool.
You should be able to see the USB port.
Now you will be able to desolder the faulty USB port.
Here is a link on desoldering Hoe moet je (de-)solderen?
Één andere persoon heeft deze handleiding voltooid.
