Ga door naar hoofdinhoud
Asus F6A-X2 RAM Replacement
Wat je nodig hebt
    1. Asus F6A-X2 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
      • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
      • Flip laptop face down and rotate so the battery is facing toward you.
      • The battery is not shown in this picture.
      • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
      • Slide the battery toward you and lift it out of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. Asus F6A-X2 RAM Replacement, Back Access Panel: stap 2, afbeelding 1 van 2 Asus F6A-X2 RAM Replacement, Back Access Panel: stap 2, afbeelding 2 van 2
      • With the laptop facing down, rotate it so the battery pack is facing away from you.
      • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus F6A-X2 RAM Replacement: stap 3, afbeelding 1 van 3 Asus F6A-X2 RAM Replacement: stap 3, afbeelding 2 van 3 Asus F6A-X2 RAM Replacement: stap 3, afbeelding 3 van 3
      • Insert a finger into one of the slots on the bottom panel.
      • Gently lift the upwards, and the back panel of the laptop will come off easily.
      Vraag FixBot
      Voeg opmerking toe
    1. Asus F6A-X2 RAM Replacement, RAM: stap 4, afbeelding 1 van 2 Asus F6A-X2 RAM Replacement, RAM: stap 4, afbeelding 2 van 2
      • Make sure to check the RAM specifications on the device page.
      • There are two white plastic tabs holding the RAM in place. Place two fingers on each of these tabs, and pull outward.
      • You will hear a pop and visibly see the RAM move upwards.
      • Slide the RAM towards the back end of the laptop (the end with the battery), and lift up to remove it.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus F6A-X2 RAM Replacement: stap 5, afbeelding 1 van 2 Asus F6A-X2 RAM Replacement: stap 5, afbeelding 2 van 2
      • Repeat the process from the previous step to remove the bottom RAM.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jonathan
1.174 Reputatie
11 handleidingen geschreven
Cal Poly, Team 10-56, Amido Spring 2014 Lid van Cal Poly, Team 10-56, Amido Spring 2014
CPSU-AMIDO-S14S10G56
4 Leden
12 handleidingen geschreven
1Gids Commentaar
Tutorel simple et très clair.
Merci
alainbadinier - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 938
