Ga door naar hoofdinhoud
Asus Eee PC 900 Webcam Replacement
Wat je nodig hebt
  1. Asus Eee PC 900 Webcam Replacement, Battery: stap 1, afbeelding 1 van 3 Asus Eee PC 900 Webcam Replacement, Battery: stap 1, afbeelding 2 van 3 Asus Eee PC 900 Webcam Replacement, Battery: stap 1, afbeelding 3 van 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus Eee PC 900 Webcam Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus Eee PC 900 Webcam Replacement, Keyboard: stap 3, afbeelding 1 van 2 Asus Eee PC 900 Webcam Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus Eee PC 900 Webcam Replacement: stap 4, afbeelding 1 van 2 Asus Eee PC 900 Webcam Replacement: stap 4, afbeelding 2 van 2
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus Eee PC 900 Webcam Replacement: stap 5, afbeelding 1 van 1
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus Eee PC 900 Webcam Replacement: stap 6, afbeelding 1 van 1
    • Remove the keyboard by lifting upwards.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus Eee PC 900 Webcam Replacement, Top Cover: stap 7, afbeelding 1 van 2 Asus Eee PC 900 Webcam Replacement, Top Cover: stap 7, afbeelding 2 van 2
    • Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  8. Asus Eee PC 900 Webcam Replacement: stap 8, afbeelding 1 van 2 Asus Eee PC 900 Webcam Replacement: stap 8, afbeelding 2 van 2
    • Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  9. Asus Eee PC 900 Webcam Replacement: stap 9, afbeelding 1 van 3 Asus Eee PC 900 Webcam Replacement: stap 9, afbeelding 2 van 3 Asus Eee PC 900 Webcam Replacement: stap 9, afbeelding 3 van 3
    • Flip the laptop back over and identify the touchpad ribbon.
    • Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
    Vraag FixBot
    Voeg opmerking toe
  10. Asus Eee PC 900 Webcam Replacement: stap 10, afbeelding 1 van 1
    • Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
    Vraag FixBot
    Voeg opmerking toe
  11. Asus Eee PC 900 Webcam Replacement: stap 11, afbeelding 1 van 1
    • Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
    Vraag FixBot
    Voeg opmerking toe
  12. Asus Eee PC 900 Webcam Replacement: stap 12, afbeelding 1 van 3 Asus Eee PC 900 Webcam Replacement: stap 12, afbeelding 2 van 3 Asus Eee PC 900 Webcam Replacement: stap 12, afbeelding 3 van 3
    • Caution: To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage.
    • Remove the laptop cover.
    Vraag FixBot
    Voeg opmerking toe
  13. Asus Eee PC 900 Webcam Replacement, LCD Display Screen: stap 13, afbeelding 1 van 3 Asus Eee PC 900 Webcam Replacement, LCD Display Screen: stap 13, afbeelding 2 van 3 Asus Eee PC 900 Webcam Replacement, LCD Display Screen: stap 13, afbeelding 3 van 3
    • Remove the large black wire using a plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  14. Asus Eee PC 900 Webcam Replacement: stap 14, afbeelding 1 van 3 Asus Eee PC 900 Webcam Replacement: stap 14, afbeelding 2 van 3 Asus Eee PC 900 Webcam Replacement: stap 14, afbeelding 3 van 3
    • Gently pry off the six rubber covers around the outside of the screen using a two mm flat head screwdriver.
    • A flat head screwdriver is preferable over a spudger as the spudger's head is not thin enough to to slip under the rubber covers.
    • Remove the six 4.76 mm Phillips #0 screws underneath each cover.
    Vraag FixBot
    Voeg opmerking toe
  15. Asus Eee PC 900 Webcam Replacement: stap 15, afbeelding 1 van 1
    • Using a plastic opening tool, carefully detach the casing around the screen cover.
    • Remove the screen cover.
    Vraag FixBot
    Voeg opmerking toe
  16. Asus Eee PC 900 Webcam Replacement: stap 16, afbeelding 1 van 3 Asus Eee PC 900 Webcam Replacement: stap 16, afbeelding 2 van 3 Asus Eee PC 900 Webcam Replacement: stap 16, afbeelding 3 van 3
    • Remove the four 4.76mm Phillips #0 screws located on the corners of the screen.
    • Lift out the display screen.
    Vraag FixBot
    Voeg opmerking toe
  17. Asus Eee PC 900 Webcam Replacement, Webcam: stap 17, afbeelding 1 van 3 Asus Eee PC 900 Webcam Replacement, Webcam: stap 17, afbeelding 2 van 3 Asus Eee PC 900 Webcam Replacement, Webcam: stap 17, afbeelding 3 van 3
    • Detach the small white plug located to the left of the webcam with a spudger.
    • It may be helpful to hold down the webcam unit with a finger.
    Vraag FixBot
    Voeg opmerking toe
  18. Asus Eee PC 900 Webcam Replacement: stap 18, afbeelding 1 van 1
    • Carefully lift the webcam off of its placeholders starting from the left side.
    • There may be a small amount of adhesive attached to the back of the webcam. Use the end of a spudger to carefully remove the adhesive.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Michael Barker
299 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-27, Amido Winter 2012 Lid van Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 9,450
