Ga door naar hoofdinhoud
Asus Eee PC 1201N Display Replacement
Wat je nodig hebt
  1. Asus Eee PC 1201N Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus Eee PC 1201N Display Replacement: stap 2, afbeelding 1 van 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus Eee PC 1201N Display Replacement: stap 3, afbeelding 1 van 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus Eee PC 1201N Display Replacement, Display: stap 4, afbeelding 1 van 2 Asus Eee PC 1201N Display Replacement, Display: stap 4, afbeelding 2 van 2
    • Remove the six screw on the front cover by using the plastic opening tool. Then, remove the six 4.6mm screws using the J0 Phillips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus Eee PC 1201N Display Replacement: stap 5, afbeelding 1 van 1
    • Using the plastic opening tool, separate the over from the netbook.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus Eee PC 1201N Display Replacement: stap 6, afbeelding 1 van 1
    • You must separate the hinge cover from the cover before removing the cover.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus Eee PC 1201N Display Replacement: stap 7, afbeelding 1 van 1
    • After removing the cover, remove the two 4.6mm screws using the J0 Phillips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Asus Eee PC 1201N Display Replacement: stap 8, afbeelding 1 van 1
    • There are two screws on the left and right side of the display. Remove all four 3mm screws using the J0 Phillips head to separate the LCD from the display cover.
    • The left side will have a magnet covering the bottom screw remove the magnet. Be sure to replace when reassembling.
    Vraag FixBot
    Voeg opmerking toe
  9. Asus Eee PC 1201N Display Replacement: stap 9, afbeelding 1 van 1
    • Pull up on the video cable on the back of the LCD display to remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
USF Tampa, Team 2-3, Nance Fall 2016 Lid van USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 949
