Ga door naar hoofdinhoud
Asus Eee PC 1005PEB Keyboard Replacement
Wat je nodig hebt
  1. Asus Eee PC 1005PEB Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus Eee PC 1005PEB Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus Eee PC 1005PEB Keyboard Replacement: stap 3, afbeelding 1 van 2 Asus Eee PC 1005PEB Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus Eee PC 1005PEB Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Using both hands, pull the battery horizontally away from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus Eee PC 1005PEB Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 1
    • Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus Eee PC 1005PEB Keyboard Replacement: stap 6, afbeelding 1 van 3 Asus Eee PC 1005PEB Keyboard Replacement: stap 6, afbeelding 2 van 3 Asus Eee PC 1005PEB Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Using the wide opening tool, unhook each clip from its original position by pulling the clip towards you.
    • Repeat for all four of the clips.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus Eee PC 1005PEB Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Turn the laptop right side up and lift the lid.
    • Insert the flat end of the spudger into the small gap between the top of the keyboard and the plastic of the laptop.
    • Using the spudger as leverage, lift the keyboard up from the rest of the laptop.
    • Run the spudger across the seam until the entire top edge is exposed. The two sides of the keyboard should also pop up in this process.
    Vraag FixBot
    Voeg opmerking toe
  8. Asus Eee PC 1005PEB Keyboard Replacement: stap 8, afbeelding 1 van 1
    • The keyboard should now lift from the base of the laptop.
    • Do not lift the keyboard up to quickly or too hard, since a ribbon cable is still attached to the keyboard and doing so could break it.
    Vraag FixBot
    Voeg opmerking toe
  9. Asus Eee PC 1005PEB Keyboard Replacement: stap 9, afbeelding 1 van 3 Asus Eee PC 1005PEB Keyboard Replacement: stap 9, afbeelding 2 van 3 Asus Eee PC 1005PEB Keyboard Replacement: stap 9, afbeelding 3 van 3
    • Using the pointed end of the spudger tool, disconnect the ribbon cable that extends from the bottom of the keyboard to the computer by pushing on the connections of the cable.
    • Once the ribbon cable is disconnected, the keyboard can be fully removed by lifting it away from the laptop.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Aaron Arenas
751 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-32, Maness Spring 2014 Lid van Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 1,659
