Ga door naar hoofdinhoud
Asus Chromebook C201 Keyboard Replacement
Wat je nodig hebt
  1. Asus Chromebook C201 Keyboard Replacement, Palm Rest Assembly: stap 1, afbeelding 1 van 1
    • Flip the laptop upside down with the rear end of the computer away from you.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus Chromebook C201 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus Chromebook C201 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus Chromebook C201 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus Chromebook C201 Keyboard Replacement: stap 5, afbeelding 1 van 2 Asus Chromebook C201 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus Chromebook C201 Keyboard Replacement: stap 6, afbeelding 1 van 3 Asus Chromebook C201 Keyboard Replacement: stap 6, afbeelding 2 van 3 Asus Chromebook C201 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus Chromebook C201 Keyboard Replacement: stap 7, afbeelding 1 van 2 Asus Chromebook C201 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  8. Asus Chromebook C201 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the keyboard cover and safely place it somewhere face down.
    Vraag FixBot
    Voeg opmerking toe
  9. Asus Chromebook C201 Keyboard Replacement, Keyboard: stap 9, afbeelding 1 van 1
    • Use a J0 screwdriver to remove the two 3mm JIS 0 keyboard screws.
    Vraag FixBot
    Voeg opmerking toe
  10. Asus Chromebook C201 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Pull the tape connecting the keys from the palm rest assembly.
    Vraag FixBot
    Voeg opmerking toe
  11. Asus Chromebook C201 Keyboard Replacement: stap 11, afbeelding 1 van 2 Asus Chromebook C201 Keyboard Replacement: stap 11, afbeelding 2 van 2
    • Gently, with force, pop the keyboard from the palm rest assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Robert Lawson
841 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-51, Cagle Spring 2016 Lid van USF Tampa, Team 2-51, Cagle Spring 2016
USFT-CAGLE-S16S2G51
4 Leden
10 handleidingen geschreven
2Gids Commentaar
Thanks!
Took me about 30 minutes, despite losing a couple of screws (which I did find on the floor/chair), interruptions from kids, and forgetting to put a little rubber pad on the new keyboard, requiring almost complete re-disassembly and assembly.
Only real issue I had was that the old keyboard coming out was basically snapping off little bits of the white keyboard case. (The “gently with force” section.) I suspect that it’s designed as a one-way connection and removal will break those little snaps irrespective of what care is taken. But reassembling it seems to work without those snaps just fine.
Thanks!
Jake - Antwoord Deel
A couple more notes:
I did it without removing the cable for the touchpad at all. I didn’t see any reason to disconnect that.
After examining the old keyboard more carefully, I realized the plastic sheet on the bottom was removable (it’s just glued on) and should be affixed to the bottom of the old one, so once more I took it apart and added that back. (That sheet had probably saved the computer from killing more than the keyboard when coffee was spilled.)
Also, the two slightly longer screws go under the rubber feet.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 5,436
