Ga door naar hoofdinhoud
Asus CM1745 CD Drive Replacement
Wat je nodig hebt
  1. Asus CM1745 CD Drive Replacement, CD Drive: stap 1, afbeelding 1 van 2 Asus CM1745 CD Drive Replacement, CD Drive: stap 1, afbeelding 2 van 2
    • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus CM1745 CD Drive Replacement: stap 2, afbeelding 1 van 3 Asus CM1745 CD Drive Replacement: stap 2, afbeelding 2 van 3 Asus CM1745 CD Drive Replacement: stap 2, afbeelding 3 van 3
    • Remove the two cables connected to the CD Tray
    • Remove the two screws with a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus CM1745 CD Drive Replacement: stap 3, afbeelding 1 van 3 Asus CM1745 CD Drive Replacement: stap 3, afbeelding 2 van 3 Asus CM1745 CD Drive Replacement: stap 3, afbeelding 3 van 3
    • Flip the computer over and remove the other side panel by unscrewing the two screws on the rear.
    • Slide the side panel off and remove the two screws that are attached to the CD Tray with a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus CM1745 CD Drive Replacement: stap 4, afbeelding 1 van 3 Asus CM1745 CD Drive Replacement: stap 4, afbeelding 2 van 3 Asus CM1745 CD Drive Replacement: stap 4, afbeelding 3 van 3
    • Remove the front panel using the iFixit opening tool.
    • You will first pull the visible clips off of the chassis as seen in the second photo then use the opening tool to pry the other clips off.
    • Once a few of the clips pop open, pull the front panel off with relative ease.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus CM1745 CD Drive Replacement: stap 5, afbeelding 1 van 3 Asus CM1745 CD Drive Replacement: stap 5, afbeelding 2 van 3 Asus CM1745 CD Drive Replacement: stap 5, afbeelding 3 van 3
    • With the front panel removed, push the CD tray from the back, outwards. If no screws are left, it should slide right out.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus CM1745 CD Drive Replacement: stap 6, afbeelding 1 van 3 Asus CM1745 CD Drive Replacement: stap 6, afbeelding 2 van 3 Asus CM1745 CD Drive Replacement: stap 6, afbeelding 3 van 3
    • Place the new CD Drive in the place of the old one and secure it by rescrewing the previous screws. Reattach the two connectors for power and data on the back.
    • Reattach the front panel after reinstalling the CD Drive by orienting the panel with the chassis and pressing it into place.
    • Make sure all clips are re-secured by pushing around the perimeter.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
If everything looks correct, boot the computer and check to see if the CD Tray works as intended. If so, reassemble the case.
TC Fowlar
896 Reputatie
5 handleidingen geschreven
1Gids Commentaar
This knowledge can also help you to develop technology-based solutions on your own, should you develop an interest in it.
Coding teaches you how to think
As some of the most successful people in business today are those having majors in computer science and having sufficient background in programming, it is clear that programming also helps you to think logically, use essay writer services, which can be a valuable asset no matter where you are working. It enables people to think clearly and make correct decisions.
It is clear that for several reasons, coding has become one of the most important skills needed nowadays, and it will be best to encourage children to learn this skill as soon as they can.
Steven Gentry - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 62
Altijd: 2,263
