Ga door naar hoofdinhoud
Asus A53S I/O Board Replacement
Wat je nodig hebt
  1. Asus A53S I/O Board Replacement, I/O Board: stap 1, afbeelding 1 van 3 Asus A53S I/O Board Replacement, I/O Board: stap 1, afbeelding 2 van 3 Asus A53S I/O Board Replacement, I/O Board: stap 1, afbeelding 3 van 3
    • Power off your device and remove the battery before beginning this guide.
    • Flip the laptop so the underside is facing up.
    • Using a Phillips #01 screwdriver, unscrew the two 6 mm screws.
    • Remove the back plate.
    • Separate your screws by step for easier assembly.
  2. Asus A53S I/O Board Replacement: stap 2, afbeelding 1 van 2 Asus A53S I/O Board Replacement: stap 2, afbeelding 2 van 2
    • Place the spudger under the white wire and pull it up gently, disconnecting it from the wifi card.
    • Use the same method on the black wire.
  3. Asus A53S I/O Board Replacement: stap 3, afbeelding 1 van 3 Asus A53S I/O Board Replacement: stap 3, afbeelding 2 van 3 Asus A53S I/O Board Replacement: stap 3, afbeelding 3 van 3
    • Push the hard drive to the left and remove it.
  4. Asus A53S I/O Board Replacement: stap 4, afbeelding 1 van 2 Asus A53S I/O Board Replacement: stap 4, afbeelding 2 van 2
    • Using a Phillips #01 screwdriver, unscrew the fifteen 6 mm screws at the indicated places.
  5. Asus A53S I/O Board Replacement: stap 5, afbeelding 1 van 2 Asus A53S I/O Board Replacement: stap 5, afbeelding 2 van 2
    • Flip over the laptop and open it.
    • Using the spudger, insert the flat end into the notches at the top of the keyboard and slowly slide and "pop" the keyboard up and out of the device.
  6. Asus A53S I/O Board Replacement: stap 6, afbeelding 1 van 2 Asus A53S I/O Board Replacement: stap 6, afbeelding 2 van 2
    • Using the flat end of the spudger, lift the black ZIF connector lock bar and disconnect the keyboard from the computer.
    • Remove the keyboard.
  7. Asus A53S I/O Board Replacement: stap 7, afbeelding 1 van 2 Asus A53S I/O Board Replacement: stap 7, afbeelding 2 van 2
    • Using the spudger, place the flat end under the ZIF connector lock bar holding the power switch. Push the spudger up and to the left, disconnecting the power switch.
    • Use the same technique on the touchpad to disconnect it.
  8. Asus A53S I/O Board Replacement: stap 8, afbeelding 1 van 2 Asus A53S I/O Board Replacement: stap 8, afbeelding 2 van 2
    • Using a Phillips #01 screwdriver, unscrew the seven 6 mm screws at the indicated places.
  9. Asus A53S I/O Board Replacement: stap 9, afbeelding 1 van 1
    • Gently pull out the optical drive.
  10. Asus A53S I/O Board Replacement: stap 10, afbeelding 1 van 1
    • Flip the laptop back over so that the bottom is facing up.
    • Use a Phillips #01 screwdriver to unscrew the three 6 mm screws at the indicated places.
  11. Asus A53S I/O Board Replacement: stap 11, afbeelding 1 van 2 Asus A53S I/O Board Replacement: stap 11, afbeelding 2 van 2
    • Turn the laptop back over so that you can open it.
    • Gently separate the cover from the laptop by putting an iFixit Opening Tool between the cover and the lower part of the laptop and levering them apart.
  12. Asus A53S I/O Board Replacement: stap 12, afbeelding 1 van 1
    • Remove the yellow tape.
  13. Asus A53S I/O Board Replacement: stap 13, afbeelding 1 van 2 Asus A53S I/O Board Replacement: stap 13, afbeelding 2 van 2
    • Using the flat end of a spudger, flip up the ZIF connector lock bar, disconnecting the USB board from the mother board.
    • Repeat this technique on the other side of the USB connector.
  14. Asus A53S I/O Board Replacement: stap 14, afbeelding 1 van 3 Asus A53S I/O Board Replacement: stap 14, afbeelding 2 van 3 Asus A53S I/O Board Replacement: stap 14, afbeelding 3 van 3
    • Using a Phillips #01 screwdriver, unscrew the 5 mm screw at the indicated place.
    • Gently remove the USB board.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Laurie Medina
638 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 235
