Ga door naar hoofdinhoud
Asus 1015E-DS03 Keyboard Replacement
Wat je nodig hebt
    1. Asus 1015E-DS03 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Hold the laptop using both hands with the battery facing upwards.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus 1015E-DS03 Keyboard Replacement: stap 2, afbeelding 1 van 1
      • Push the two tabs located below the battery in towards each other using your thumbs.
      Vraag FixBot
      Voeg opmerking toe
    3. Asus 1015E-DS03 Keyboard Replacement: stap 3, afbeelding 1 van 1
      • Push the battery upwards and out of the laptop as shown.
      Vraag FixBot
      Voeg opmerking toe
    4. Asus 1015E-DS03 Keyboard Replacement: stap 4, afbeelding 1 van 1
      • Continue to push the battery upwards until it is completely separated from the laptop as shown.
      Vraag FixBot
      Voeg opmerking toe
    1. Asus 1015E-DS03 Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 1
      • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
      • Be very careful not to lose the screws, these four screws are very small.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus 1015E-DS03 Keyboard Replacement: stap 6, afbeelding 1 van 2 Asus 1015E-DS03 Keyboard Replacement: stap 6, afbeelding 2 van 2
      • After all four screws are removed, flip the laptop over with the keyboard facing up.
      • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
      • It is normal to hear cracking noises when prying off the keyboard.
      • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Asus 1015E-DS03 Keyboard Replacement: stap 7, afbeelding 1 van 1
      • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
      • Be careful not to tear or rip the ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    4. Asus 1015E-DS03 Keyboard Replacement: stap 8, afbeelding 1 van 1
      • Using the spudger push the white clips upwards that are holding the cable.
      Vraag FixBot
      Voeg opmerking toe
    5. Asus 1015E-DS03 Keyboard Replacement: stap 9, afbeelding 1 van 2 Asus 1015E-DS03 Keyboard Replacement: stap 9, afbeelding 2 van 2
      • Gently pull the strip out of the square slot.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Joe Capriola
494 Reputatie
3 handleidingen geschreven
Clemson, Team 7-4, Benson Spring 2016 Lid van Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 36
Altijd: 1,604
