Inleiding
Use this guide to remove control buttons for cleaning or replacement.
Wat je nodig hebt
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Gently insert a metal spudger under a control button housing.
Rotate the control button around the marked pin.
3 andere personen hebben deze handleiding voltooid.
