Ga door naar hoofdinhoud
Astro A50 Battery Replacement
Wat je nodig hebt
  1. Astro A50 Battery  Replacement, Battery: stap 1, afbeelding 1 van 3 Astro A50 Battery  Replacement, Battery: stap 1, afbeelding 2 van 3 Astro A50 Battery  Replacement, Battery: stap 1, afbeelding 3 van 3
    • To begin, remove the foam cushions from each earpiece by gently pulling the cushion away from the housing.
    • Use a small Phillips-head screwdriver to remove the 4 screws.
  2. Astro A50 Battery  Replacement: stap 2, afbeelding 1 van 3 Astro A50 Battery  Replacement: stap 2, afbeelding 2 van 3 Astro A50 Battery  Replacement: stap 2, afbeelding 3 van 3
    • Take extra care when removing objects that are glued down as they are subject to tear.
    • After setting aside the black plastic covers, use the screwdriver again to remove the two screws.
    • Identify the foam inner covers and peel back the upper corners of each foam to expose and remove the screws beneath.
  3. Astro A50 Battery  Replacement: stap 3, afbeelding 1 van 2 Astro A50 Battery  Replacement: stap 3, afbeelding 2 van 2
    • Gently fold aside the speaker assembly to expose the internals of the earpiece. Use caution to avoid damaging the black wires.
    • Remove the four screws marked in red to release the faceplate on the outside of the headset.
  4. Astro A50 Battery  Replacement: stap 4, afbeelding 1 van 2 Astro A50 Battery  Replacement: stap 4, afbeelding 2 van 2
    • Turn the earpiece over, and expose the battery by folding the microphone and cover plate away from the battery housing.
    • Desolder battery connections to disconnect the three colored wires from the old battery. Make note of corresponding colors/locations for installation of new battery.
    • Carefully remove the old battery by wedging a plastic opening tool or spudger underneath the battery to release the adhesive.
    • Do not bend or puncture the battery housing.
    • For reassembly, follow steps 1-4 in reverse order:
    • Take care to ensure battery wires are soldered correctly with each color on its corresponding pad.
    • Use minimal amounts of adhesive to re-attach the speaker foam to avoid glue making a mess.
Conclusie
Be sure to test your new battery to make sure the fix succeeded.
40 andere personen hebben deze handleiding voltooid.
Nicholas Eriksen
987 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-5, Shastany Fall 2015 Lid van UMass Dartmouth, Team 2-5, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G5
4 Leden
10 handleidingen geschreven
33Gids Commentaar
Could you post the dimensions of the battery itself? Seems like it's hard to find one that may or may not fit. That or could you recommend where to get a battery?
lolubad umad - Antwoord Deel
i'd also like to know where to source the battery
drbob44 - Antwoord Deel
Search for part no: 603443 on Ebay - ~$10 or buy one from Astro for $75
mattgorringe - Antwoord Deel
So, which battery is the best replacement for the original? Is it possible to put some bigger batteries inside with some modding?
Rene Siekmann - Antwoord Deel
Battery sizes are mAH, just by a 900 or more and that should do the trick. The actual size of the battery must be identical for a perfect fit and confortable headsets. Just make sure you get the correct voltage and size.
The battery comes with a cable, instead of soldering, can I tie those cables in? Also, what is the best way to remove and reattach foam cushions without damaging them?
cpaalvarez - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 187
Altijd: 100,119
