Ga door naar hoofdinhoud
Astro A50 2016 Headset Battery Replacement
Wat je nodig hebt
  1. Astro A50 2016  Headset Battery Replacement, Headset Speakers: stap 1, afbeelding 1 van 2 Astro A50 2016  Headset Battery Replacement, Headset Speakers: stap 1, afbeelding 2 van 2
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016  Headset Battery Replacement: stap 2, afbeelding 1 van 1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016  Headset Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016  Headset Battery Replacement: stap 4, afbeelding 1 van 1
    • Lift the speaker module up off the device.
  5. Astro A50 2016  Headset Battery Replacement, Headset Battery: stap 5, afbeelding 1 van 2 Astro A50 2016  Headset Battery Replacement, Headset Battery: stap 5, afbeelding 2 van 2
    • Remove the five 6mm PH1 screws.
    • Remove the buttons panel by pulling the panel away from the white ribbon cord.
  6. Astro A50 2016  Headset Battery Replacement: stap 6, afbeelding 1 van 2 Astro A50 2016  Headset Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove the four 6mm PH1 screws.
    • Remove the tape holding the wires connected to the motherboard.
  7. Astro A50 2016  Headset Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the back panel by squeezing the two tabs together and pushing out.
  8. Astro A50 2016  Headset Battery Replacement: stap 8, afbeelding 1 van 1
  9. Astro A50 2016  Headset Battery Replacement: stap 9, afbeelding 1 van 1
    • Remove the battery by using the plastic opening tool to pry it away from the headset.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Andrew Monson
502 Reputatie
1 Handleiding geschreven
Cal Poly, Team S15-G1, Livingston Fall 2017 Lid van Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Leden
10 handleidingen geschreven
10 opmerkingen
Is this for the Gen III Astro a50?
vic.bianco - Antwoord
Yes it’s for the Gen 3 A50
Crisdavid -
Where do I buy a battery though….
Brandon Phillips - Antwoord
how can I connect the new battery ?
Ahmed f - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 72
Afgelopen 30 dagen: 336
Altijd: 25,906
