Wat je nodig hebt
To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
Remove the three screws in the photo with the J00 driver bit, and pull the headphone jack away from the assembly.
Pull the motherboard off of the jack and replace it with a new one by re-soldering the wires.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Hi I hope you can answer ASAP
Why did you replace that?
I’m asking this cuz i got a problem with mines, i insert the mic and didn’t work, its like a false
