Ga door naar hoofdinhoud
Astro A40 Gen2 Mixamp Button Replacement
Wat je nodig hebt
    1. Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: stap 1, afbeelding 1 van 3 Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: stap 1, afbeelding 2 van 3 Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: stap 1, afbeelding 3 van 3
      • Remove the dials using either a metal spudger or your hands. Be careful as the dials may be difficult to remove.
      Vraag FixBot
      Voeg opmerking toe
    1. Astro A40 Gen2 Mixamp Button Replacement, Remove nuts and washers.: stap 2, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Locate the two 11/32 inch nuts underneath the dials.
      • Use an 11/32 inch socket wrench or tweezers to unscrew and remove the nuts and washers.
      Vraag FixBot
      Voeg opmerking toe
    2. Astro A40 Gen2 Mixamp Button Replacement, Remove back pad.: stap 3, afbeelding 1 van 2 Astro A40 Gen2 Mixamp Button Replacement, Remove back pad.: stap 3, afbeelding 2 van 2
      • Using a larger metal spudger, remove the rubber back of the mixamp.
      • The back will have glue residue after removal. Depending on the stickiness of the residue, more glue may be needed to stick the backing back on.
      Vraag FixBot
      Voeg opmerking toe
    3. Astro A40 Gen2 Mixamp Button Replacement, Take out main case screw.: stap 4, afbeelding 1 van 1
      • Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
      Vraag FixBot
      Voeg opmerking toe
    4. Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: stap 5, afbeelding 1 van 3 Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: stap 5, afbeelding 2 van 3 Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: stap 5, afbeelding 3 van 3
      • Using a large metal spudger, detach all plastic clips holding the bottom and top casings together.
      • Remove the input casing using your fingers.
      • Be careful when releasing the clips between the two casings, as it is very easy to scratch the mixamp or break the clips.
      • Use caution when pulling the two casings apart as it is very easy to pinch your fingers between them.
      Vraag FixBot
      Voeg opmerking toe
    5. Astro A40 Gen2 Mixamp Button Replacement, Remove the motherboard from the case.: stap 6, afbeelding 1 van 1
      • Remove the four 5.8 mm Phillips #0 screws on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. Astro A40 Gen2 Mixamp Button Replacement: stap 7, afbeelding 1 van 2 Astro A40 Gen2 Mixamp Button Replacement: stap 7, afbeelding 2 van 2
      • Remove the motherboard from the casing.
      Vraag FixBot
      Voeg opmerking toe
    1. Astro A40 Gen2 Mixamp Button Replacement, Mixamp Button: stap 8, afbeelding 1 van 2 Astro A40 Gen2 Mixamp Button Replacement, Mixamp Button: stap 8, afbeelding 2 van 2
      • Use a metal spudger to pry off the buttons and remove them.
      • You may need to apply pressure to break off the small black caps which hold the buttons down. The buttons will still function without the black caps.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Mark
412 Reputatie
3 handleidingen geschreven
Cal Poly, Team 20-18, Maness Winter 2015 Lid van Cal Poly, Team 20-18, Maness Winter 2015
CPSU-MANESS-W15S20G18
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 2,666
