Ga door naar hoofdinhoud
Astro A20 Microphone Replacement
Wat je nodig hebt
    1. Astro A20  Microphone Replacement, Cushion: stap 1, afbeelding 1 van 1
      • Place one hand on the hard side of the headset ear portion and on the cushion.
      • Lift the small portion on the edge of the cushion.
      Vraag FixBot
      Voeg opmerking toe
    2. Astro A20  Microphone Replacement: stap 2, afbeelding 1 van 1
      • Slide the metal spudger underneath the lift part of the ear cushion.
      • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
      Vraag FixBot
      Voeg opmerking toe
    3. Astro A20  Microphone Replacement: stap 3, afbeelding 1 van 2 Astro A20  Microphone Replacement: stap 3, afbeelding 2 van 2
      • Remove the ear cushion from the headset.
      Vraag FixBot
      Voeg opmerking toe
    1. Astro A20  Microphone Replacement, Microphone: stap 4, afbeelding 1 van 1
      • Place one hand on the back of the speaker.
      Vraag FixBot
      Voeg opmerking toe
    2. Astro A20  Microphone Replacement: stap 5, afbeelding 1 van 2 Astro A20  Microphone Replacement: stap 5, afbeelding 2 van 2
      • Remove the four 7mm screws with a Phillips #1 screwdriver.
      • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
      Vraag FixBot
      Voeg opmerking toe
    3. Astro A20  Microphone Replacement: stap 6, afbeelding 1 van 2 Astro A20  Microphone Replacement: stap 6, afbeelding 2 van 2
      • Lift the speaker area.
      • Disconnect the wires that connect the microphone.
      • Remove the 7mm screw with a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Jasmine Yarbrough
1.017 Reputatie
5 handleidingen geschreven
5Gids Commentaar
worked for me….thanks
Thompson Crusher - Antwoord Deel
listen my mic peace is messed up is there like a fix for that
Bruh Bruh - Antwoord Deel
were? are you getting the new mic from? please link the site
jrod6t9 - Antwoord Deel
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
Lineth Jauregui - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 125
Altijd: 15,741
