Ga door naar hoofdinhoud
Aroma ARC-914SBD Control Module Replacement
Wat je nodig hebt
    1. Aroma ARC-914SBD Control Module Replacement, Lid: stap 1, afbeelding 1 van 2 Aroma ARC-914SBD Control Module Replacement, Lid: stap 1, afbeelding 2 van 2
      • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
      Vraag FixBot
      Voeg opmerking toe
    2. Aroma ARC-914SBD Control Module Replacement: stap 2, afbeelding 1 van 1
      • Once the condensation catcher has been removed, set it aside for reassembly later.
      • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
      Vraag FixBot
      Voeg opmerking toe
    3. Aroma ARC-914SBD Control Module Replacement: stap 3, afbeelding 1 van 2 Aroma ARC-914SBD Control Module Replacement: stap 3, afbeelding 2 van 2
      • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
      Vraag FixBot
      Voeg opmerking toe
    4. Aroma ARC-914SBD Control Module Replacement: stap 4, afbeelding 1 van 3 Aroma ARC-914SBD Control Module Replacement: stap 4, afbeelding 2 van 3 Aroma ARC-914SBD Control Module Replacement: stap 4, afbeelding 3 van 3
      • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Aroma ARC-914SBD Control Module Replacement, Heating Element/ Thermostat: stap 5, afbeelding 1 van 2 Aroma ARC-914SBD Control Module Replacement, Heating Element/ Thermostat: stap 5, afbeelding 2 van 2
      • Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry this piece from the bottom to get the tab from behind the stainless steel to in front of the steel as shown.
      Vraag FixBot
      Voeg opmerking toe
    2. Aroma ARC-914SBD Control Module Replacement: stap 6, afbeelding 1 van 2 Aroma ARC-914SBD Control Module Replacement: stap 6, afbeelding 2 van 2
      • Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
      Vraag FixBot
      Voeg opmerking toe
    3. Aroma ARC-914SBD Control Module Replacement: stap 7, afbeelding 1 van 2 Aroma ARC-914SBD Control Module Replacement: stap 7, afbeelding 2 van 2
      • Using a Phillips head screwdriver, size PH2, remove the screws from the control module to expose wired connections.
      Vraag FixBot
      Voeg opmerking toe
    4. Aroma ARC-914SBD Control Module Replacement: stap 8, afbeelding 1 van 1
      • Unplug thermostat from control module
      Vraag FixBot
      Voeg opmerking toe
    5. Aroma ARC-914SBD Control Module Replacement: stap 9, afbeelding 1 van 1
      • Remove red and blue wires from heating element to fully detach from control module. This is done by removing the screws on the heating element terminals using a Phillips head screwdriver, size PH2.
      Vraag FixBot
      Voeg opmerking toe
    6. Aroma ARC-914SBD Control Module Replacement: stap 10, afbeelding 1 van 2 Aroma ARC-914SBD Control Module Replacement: stap 10, afbeelding 2 van 2
      • Again, using a Phillips head screwdriver, size PH2, remove the three screws holding the heating element assembly to the bowl. This will remove the heating element and the thermostat.
      Vraag FixBot
      Voeg opmerking toe
    1. Aroma ARC-914SBD Control Module Replacement, Control Module: stap 11, afbeelding 1 van 1
      • Unplug the interface from the control module
      Vraag FixBot
      Voeg opmerking toe
    2. Aroma ARC-914SBD Control Module Replacement: stap 12, afbeelding 1 van 1
      • Unplug the power from the control module
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Brandon Nieves
956 Reputatie
8 handleidingen geschreven
USF Tampa, Team 2-3, Sullivan Fall 2015 Lid van USF Tampa, Team 2-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G3
3 Leden
16 handleidingen geschreven
8Gids Commentaar
I found the problem inside the unit, a blown thermal fuse on the neutral side of the power. The inside of this unit is nothing like the pictures, but the part up to removing the black rim was accurate. This unit is an SB and apparently a lesser model of the above.
Harriot Smyth - Antwoord Deel
Thanks for this, very helpful. I only needed to remove the loud, horrible beeper (mission accomplished, woohoo!) although the really hard part for some reason was rotating the tabbed black ring independently of the inside liner. Coudn't get it to budge AT ALL, as if they were glued together. I could only rotate them as a unit inside the housing. After way too long working at this, I ended up wedging a flathead into the crevice between the ring and liner, from the inside, at the two points where I could see the tabs through the hole on the outside, then just twisted the screwdriver and snapped off the tabs one at a time. There are two more tabs on the other side of the ring, but these just slide out once the first two are gone, and the liner can be easily removed. When reassembling, the black trim fits quite snugly back onto the liner, so the unit feels as solid as it did before the operation. Thanks again!
Dav e - Antwoord Deel
Dave,
I also plan to remove beeper, did you just cut it out or un-solder it? any issues?
thanks
jdelabar@gmail.com
James DeLabar - Antwoord Deel
I’m not Dave, but I used a vacuum desoldering tool to remove the beeper, which was easy. I think there would have been enough room to cut it out also. The only hard part was getting the black ring off and then back on.
David DiGiacomo - Antwoord Deel
I want one trolley module for ARC 3000SB. Where can I get. How much I have to. Pay for it approximately.
Email id pantulu.chinta@gmail.com
Pantulu Chinta - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 47
Altijd: 3,537
