Ga door naar hoofdinhoud
Arlo Ultra 2 Spotlight Replacement
Wat je nodig hebt
  1. Arlo Ultra 2 Spotlight Replacement, Battery: stap 1, afbeelding 1 van 2 Arlo Ultra 2 Spotlight Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Spotlight Replacement: stap 2, afbeelding 1 van 1
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Spotlight Replacement, Spotlight: stap 3, afbeelding 1 van 2 Arlo Ultra 2 Spotlight Replacement, Spotlight: stap 3, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity.
  4. Arlo Ultra 2 Spotlight Replacement: stap 4, afbeelding 1 van 2 Arlo Ultra 2 Spotlight Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Spotlight Replacement: stap 5, afbeelding 1 van 2 Arlo Ultra 2 Spotlight Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the two 4.00 mm black screws located across from each other above the camera lens.
  6. Arlo Ultra 2 Spotlight Replacement: stap 6, afbeelding 1 van 2 Arlo Ultra 2 Spotlight Replacement: stap 6, afbeelding 2 van 2
    • Use a spudger or your fingernail to flip up the small locking flap on the ZIF connector. Then, you can safely pull the cable out.
    • The cable is very short and you will see it when removing the circuit board.
  7. Arlo Ultra 2 Spotlight Replacement: stap 7, afbeelding 1 van 2 Arlo Ultra 2 Spotlight Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to gently pry the green circuit board away from the case.
    • Remove the green circuit board. This is your spotlight.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Great tutorial, very helpful. A suggestion however would be to also offer for sale or add links to where the replacement components can be purchased. In this instance I could not find a replacement spotlight and had to buy a donor camera. Thanks
Gareth - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 116
