Ga door naar hoofdinhoud
Archos 97 Carbon Speakers Replacement
Wat je nodig hebt
  1. Archos 97 Carbon Speakers Replacement, Speakers: stap 1, afbeelding 1 van 1
    • Pry the tablet open in the corner using an opening tool.
    • Start in the top left corner and continue clockwise until the two pieces are separated.
  2. Archos 97 Carbon Speakers Replacement: stap 2, afbeelding 1 van 3 Archos 97 Carbon Speakers Replacement: stap 2, afbeelding 2 van 3 Archos 97 Carbon Speakers Replacement: stap 2, afbeelding 3 van 3
    • Remove the tape and plug connecting the cable to the tab, and it will come loose.
    • This will loosen the cable connecting the screen to the interior of the tablet.
  3. Archos 97 Carbon Speakers Replacement: stap 3, afbeelding 1 van 2 Archos 97 Carbon Speakers Replacement: stap 3, afbeelding 2 van 2
    • Remove the black tape from the silver cable connecting the screen to the motherboard on the left side of the tablet.
    • This will loosen the gold plug.
  4. Archos 97 Carbon Speakers Replacement: stap 4, afbeelding 1 van 1
    • Once you have separated the the screen from the tablet, you can place the screen to the side. You should be looking at this part of the tablet.
    • These are the speakers.
  5. Archos 97 Carbon Speakers Replacement: stap 5, afbeelding 1 van 3 Archos 97 Carbon Speakers Replacement: stap 5, afbeelding 2 van 3 Archos 97 Carbon Speakers Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Desoldering Pump
    $3.99
    Koop
    • Desolder each of the three wires to detach the speaker wires from the tablet.
    • There are three wires that you will desolder from the motherboard. One is red, one is black, and one is white.
    • We recommend that you use a solder sucker to suck up any of the residue that the solder produces.
  6. Archos 97 Carbon Speakers Replacement: stap 6, afbeelding 1 van 2 Archos 97 Carbon Speakers Replacement: stap 6, afbeelding 2 van 2
    • Pry each of the speakers up with an opening tool.
    • Remove the speakers and their connected wires from the tablet.
Conclusie
You have now successfully replaced the internal speakers for your Archos 97 yourself. And now you understand the process for accessing and potentially repairing/replacing any other internal components in the future should the need arise.
Één andere persoon heeft deze handleiding voltooid.
Allyson Seber
311 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 440
