Inleiding
This guide will help you replace the battery in your Archos 5 tablet. Although this repair is pretty lengthy, don't be discouraged. You can do this yourself!
Wat je nodig hebt
Once you have opened your device, fold the screen away from the battery.
Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece(attached at the bottom of the metallic foil) Press the plastic spudger against the thin black piece and release it.
Once the wires have all been released remove the battery from the device and replace with a new battery. To reattach the new battery wires please refer to this guide on How To Solder
6 andere personen hebben deze handleiding voltooid.
