Ga door naar hoofdinhoud
Archos 101 G9 Display Assembly Replacement
Wat je nodig hebt
    1. Archos 101 G9 Display Assembly Replacement, Display Assembly: stap 1, afbeelding 1 van 1
      • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
      • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
      • When you reach the corner, carefully pry the two halves of the device apart.
      • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
      • Repeat for the remaining three sides and corners.
      Vraag FixBot
      Voeg opmerking toe
    2. Archos 101 G9 Display Assembly Replacement: stap 2, afbeelding 1 van 2 Archos 101 G9 Display Assembly Replacement: stap 2, afbeelding 2 van 2
      • Separate the halves of the device.
      • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
      Vraag FixBot
      Voeg opmerking toe
    3. Archos 101 G9 Display Assembly Replacement: stap 3, afbeelding 1 van 2 Archos 101 G9 Display Assembly Replacement: stap 3, afbeelding 2 van 2
      • Gently remove both ribbon cables from their sockets on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Archos 101 G9 Display Assembly Replacement: stap 4, afbeelding 1 van 1
      • Remove the white and black coaxial cables with gold tips from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Archos 101 G9 Display Assembly Replacement: stap 5, afbeelding 1 van 1
      • Remove the display assembly from the back panel.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Clay Meunier
557 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 Lid van UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G1
3 Leden
6 handleidingen geschreven
1Gids Commentaar
pls i need help
Phriday Jimoh - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 673
