Inleiding
Cracked the glass on your Apple Watch? Time to get that fixed up. Follow this guide to replace the screen—which includes the OLED display and fused glass digitizer (touchscreen).
As a precaution against damaging your device, this guide starts by disconnecting the battery, in the only way you can—by removing it.
Wat je nodig hebt
Video overzicht
Before starting repairs, take your watch off the charger and power it down.
Prepare an iOpener (or grab a hair dryer or heat gun) and heat the face of the watch until it's slightly too hot to touch.
Leave the iOpener on the watch for at least a minute to fully heat the screen and soften the adhesive holding it to the case.
Place the curved section of the blade in the gap between the glass and case on the lower edge of the watch face, and press firmly straight down into the gap.
When the glass has lifted, gently rotate the knife down, opening the gap more by pushing the glass up.
Use scissors to cut one of your opening picks to about the width of the battery. Try not to leave any sharp corners.
Insert the modified pick between the right side of the battery and the case.
Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
On the larger (42 mm) models, it's possible to accidentally pry at the system board underneath the battery. Insert the pick only far enough to get underneath the battery, not the system board.
If needed, apply a little high concentration isopropyl alcohol (90% or greater) around and under the battery to help weaken the adhesive.
Steady the bracket from the left side using your fingers or tweezers.
At the same time, insert a small (1 mm) flathead screwdriver under the tiny tab on the right.
Finally, place one finger behind the tab, and pinch the bracket hard between your finger and the screwdriver to detach the cover.
Continue from Step 22 of the Force Touch Sensor guide to re-seal your watch and complete your repair.
376 andere personen hebben deze handleiding voltooid.
69 opmerkingen
Does anyone know if I can replace my glass display for the saphier one??
Yes, they are cross compatible. Look under features at Apple Watch (42 mm, Original & Series 1) Screen
First of all WHERE CAN WE BUY A OEM GENUINE AUTHENTIC APPLE GLASS REPLACEMENT?
My question is if Apple doesnt sell oem genuine ones who will?
There are replacement touch screen/digitizer available on eBay. But the question is how do you separate the OLED display from your damaged touch screen to just replace the glass?
