Ga door naar hoofdinhoud
Apple Time Capsule Model A1254 Fan Replacement
Wat je nodig hebt
    1. Apple Time Capsule Model A1254 Fan Replacement, Back Plate: stap 1, afbeelding 1 van 3 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: stap 1, afbeelding 2 van 3 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: stap 1, afbeelding 3 van 3
      • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
      • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
      • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
      • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
      Vraag FixBot
      Voeg opmerking toe
    2. Apple Time Capsule Model A1254 Fan Replacement: stap 2, afbeelding 1 van 2 Apple Time Capsule Model A1254 Fan Replacement: stap 2, afbeelding 2 van 2
      • Remove the ten 3mm screws with a Phillips #00 screwdriver.
      • The screws with adhesive covering do not need to be removed.
      Vraag FixBot
      Voeg opmerking toe
    3. Apple Time Capsule Model A1254 Fan Replacement: stap 3, afbeelding 1 van 2 Apple Time Capsule Model A1254 Fan Replacement: stap 3, afbeelding 2 van 2
      • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
      • Pull the base of the wire close to the logic board and the connector will pop off.
      Vraag FixBot
      Voeg opmerking toe
    1. Apple Time Capsule Model A1254 Fan Replacement, Fan: stap 4, afbeelding 1 van 2 Apple Time Capsule Model A1254 Fan Replacement, Fan: stap 4, afbeelding 2 van 2
      • Orientate the back plate so that the fan is facing away from you.
      • Use the #0 Phillips Screw Drive to push the rubber shock mounts through the back plate.
      • Make sure that the head of the screw driver is centered on the head of the rubber shock mount so that it doesn't slip off causing possible injury.
      • When attaching the new fan, push the new rubber shock mounts through the back plate first. Attach the fan once all mounts are inserted.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
JR Alfano
543 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-2, Livingston Fall 2016 Lid van Cal Poly, Team 4-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G2
4 Leden
22 handleidingen geschreven
2Gids Commentaar
Hi where can I find the new rubber shock mount replacement for A-1254 fan replacement? thx.
V Q - Antwoord Deel
How do I get the rubber feet off the old fan and put them on the new fan?
Jim Matthews - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 5,353
