Ga door naar hoofdinhoud
Apple Thunderbolt Display LCD Replacement
Wat je nodig hebt
  1. Apple Thunderbolt Display LCD Replacement, LCD: stap 1, afbeelding 1 van 3 Apple Thunderbolt Display LCD Replacement, LCD: stap 1, afbeelding 2 van 3 Apple Thunderbolt Display LCD Replacement, LCD: stap 1, afbeelding 3 van 3
    • Lay down the display with screen side up.
    • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
    • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
    • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
    Vraag FixBot
    Voeg opmerking toe
  2. Apple Thunderbolt Display LCD Replacement: stap 2, afbeelding 1 van 2 Apple Thunderbolt Display LCD Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the 12 screws around the side edges and the top of the LCD with the TR 10 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Apple Thunderbolt Display LCD Replacement: stap 3, afbeelding 1 van 2 Apple Thunderbolt Display LCD Replacement: stap 3, afbeelding 2 van 2
    • Slowly lift the LCD out from its placement and tilt it upwards.
    • It can be very helpful to have an extra set of hands to hold the LCD up while you work with the cables underneath.
    • There are four wires that connect the LCD to the rest of the components. Make sure not to pull hard and break any of the wires.
    Vraag FixBot
    Voeg opmerking toe
  4. Apple Thunderbolt Display LCD Replacement: stap 4, afbeelding 1 van 3 Apple Thunderbolt Display LCD Replacement: stap 4, afbeelding 2 van 3 Apple Thunderbolt Display LCD Replacement: stap 4, afbeelding 3 van 3
    • For the first of the four wires (furthest away from the wire that is held in by a screw), grab onto the connector and pull slowly.
    Vraag FixBot
    Voeg opmerking toe
  5. Apple Thunderbolt Display LCD Replacement: stap 5, afbeelding 1 van 3 Apple Thunderbolt Display LCD Replacement: stap 5, afbeelding 2 van 3 Apple Thunderbolt Display LCD Replacement: stap 5, afbeelding 3 van 3
    • For the next connector, which is right next to the previous wire, there is a piece of tape attached to a metal bar.
    • Flip the metal bar over using the tape as a handle.
    • Next, grab onto the connector and slowly pull it from the socket in the logic board.
    Vraag FixBot
    Voeg opmerking toe
  6. Apple Thunderbolt Display LCD Replacement: stap 6, afbeelding 1 van 3 Apple Thunderbolt Display LCD Replacement: stap 6, afbeelding 2 van 3 Apple Thunderbolt Display LCD Replacement: stap 6, afbeelding 3 van 3
    • For the connector on the other side of the logic board, grab the connector from underneath and carefully pull it from the board.
    Vraag FixBot
    Voeg opmerking toe
  7. Apple Thunderbolt Display LCD Replacement: stap 7, afbeelding 1 van 1
    • For the last wire connecting to the LCD, use your T 10 Screwdriver to remove the screw.
    Vraag FixBot
    Voeg opmerking toe
  8. Apple Thunderbolt Display LCD Replacement: stap 8, afbeelding 1 van 2 Apple Thunderbolt Display LCD Replacement: stap 8, afbeelding 2 van 2
    • The LCD has now been fully disconnected from the casing and can be repaired/replaced!
    • its best to set the LCD on a bed or on a thick towel to avoid damage to the LCD
    Vraag FixBot
    Voeg opmerking toe
Conclusie
30 andere personen hebben deze handleiding voltooid.
Calvin Laverty
2.310 Reputatie
4 handleidingen geschreven
Cal Poly, Team 5-11, Maness Spring 2015 Lid van Cal Poly, Team 5-11, Maness Spring 2015
CPSU-MANESS-S15S5G11
4 Leden
25 handleidingen geschreven
13Gids Commentaar
Now I just need to find the affordable replacement LCD Panel. Mine is not too bad - but it has recently developed a streak on one side that is very irksome.
gigabob - Antwoord Deel
Love your site! Proved very helpful on multiple occasions and your products are fantastic!
Forgive my ignorance...
Is it possible to (1) Are any of the components of Thunderbolt Display upgrade-able? .... (2) There appears to be plenty of real-estate, can a Thunderbolt Display be turned into mac and/or pc? ... (3) Any way to upgrade to USB 3.0/3.1?...
I like tinkering with electronics and don't mind the complexities or if necessary getting parts, just wondering if any of these are possible and if so, can you give a clue as to where I can find more info... Thank You.
Mark Karasin - Antwoord Deel
Would like to see a continuation of what it takes to replace the Thunderbolt cable that is attached to the back of the display
Michael Martin - Antwoord Deel
Hi Michael
What happen to your monitor for you to need to replace the cable. It could be solution as to why my monitor has a black screen.
Any help?
Thanks
Fm34b - Antwoord Deel
Does the LCD from an iMac 2009 27” fit into the Thunderbolt Display and make it work?
Aldo B - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 199
Altijd: 38,666
