Ga door naar hoofdinhoud
Apple TV 4K Power Connector Replacement
Wat je nodig hebt
    1. Apple TV 4K Power Connector Replacement, Logic Board: stap 1, afbeelding 1 van 1
      • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
      • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
      Vraag FixBot
      Voeg opmerking toe
    2. Apple TV 4K Power Connector Replacement: stap 2, afbeelding 1 van 2 Apple TV 4K Power Connector Replacement: stap 2, afbeelding 2 van 2
      • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
      • Four 10 mm screws
      • Lift and remove the heat sink assembly from the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Apple TV 4K Power Connector Replacement: stap 3, afbeelding 1 van 2 Apple TV 4K Power Connector Replacement: stap 3, afbeelding 2 van 2
      • Use plastic spudger to pull up on all three antenna connectors to remove them.
      • Remove rubber piece from front side of device.
      Vraag FixBot
      Voeg opmerking toe
    4. Apple TV 4K Power Connector Replacement: stap 4, afbeelding 1 van 1
      • Unscrew the following screws holding the logic board in place using the T7 Torx:
      • Two black 3 mm screws
      • Two silver 4 mm screws
      Vraag FixBot
      Voeg opmerking toe
    5. Apple TV 4K Power Connector Replacement: stap 5, afbeelding 1 van 3 Apple TV 4K Power Connector Replacement: stap 5, afbeelding 2 van 3 Apple TV 4K Power Connector Replacement: stap 5, afbeelding 3 van 3
      • Use a spudger to pry up logic board. Try lifting it up from the front side.
      • Remove logic board and set aside.
      Vraag FixBot
      Voeg opmerking toe
    1. Apple TV 4K Power Connector Replacement, Power Connector: stap 6, afbeelding 1 van 3 Apple TV 4K Power Connector Replacement, Power Connector: stap 6, afbeelding 2 van 3 Apple TV 4K Power Connector Replacement, Power Connector: stap 6, afbeelding 3 van 3
      • Use a T7 Torx to remove the screws:
      • Five 5mm screws
      • Carefully flip the device upside down to remove the logic board/power supply mount.
      Vraag FixBot
      Voeg opmerking toe
    2. Apple TV 4K Power Connector Replacement: stap 7, afbeelding 1 van 3 Apple TV 4K Power Connector Replacement: stap 7, afbeelding 2 van 3 Apple TV 4K Power Connector Replacement: stap 7, afbeelding 3 van 3
      • Disconnect the latch connecting the power connector to the power supply.
      • Feed the wire though the logic board/power supply mount. After this, remove the power connector from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Brian Gehring
499 Reputatie
2 handleidingen geschreven
UW Stout, Team S6-G3, Ogden Fall 2018 Lid van UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 81
Altijd: 4,435
