Wat je nodig hebt
As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
Before you remove completely the power supply, unscrew the T6 screws on each side of the socket.
You may now be able to remove the power supply with a spudger.
Do not pull the wires to remove the power supply. The connector is fragile.
The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
The last remaining part in the Apple TV is the status LED. You can remove this part with your plastic spudger.
4 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Step 2: “caring not to break….”. Thanks, great guide. David
