Ga door naar hoofdinhoud
Apple IIc Speaker Replacement
Wat je nodig hebt
    1. Apple IIc Speaker Replacement, Disassembling Apple IIc Cover: stap 1, afbeelding 1 van 2 Apple IIc Speaker Replacement, Disassembling Apple IIc Cover: stap 1, afbeelding 2 van 2
      • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Apple IIc Speaker Replacement: stap 2, afbeelding 1 van 2 Apple IIc Speaker Replacement: stap 2, afbeelding 2 van 2
      • Release the catch by pushing it in using a plastic opening tool.
      • The catch is off-center, but in line with the middle of the speaker underneath.
      Vraag FixBot
      Voeg opmerking toe
    3. Apple IIc Speaker Replacement: stap 3, afbeelding 1 van 2 Apple IIc Speaker Replacement: stap 3, afbeelding 2 van 2
      • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
      Vraag FixBot
      Voeg opmerking toe
    4. Apple IIc Speaker Replacement: stap 4, afbeelding 1 van 2 Apple IIc Speaker Replacement: stap 4, afbeelding 2 van 2
      • Lift the handle straight up to remove.
      Vraag FixBot
      Voeg opmerking toe
    1. Apple IIc Speaker Replacement, Keyboard: stap 5, afbeelding 1 van 2 Apple IIc Speaker Replacement, Keyboard: stap 5, afbeelding 2 van 2
      • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
      • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
      Vraag FixBot
      Voeg opmerking toe
    1. Apple IIc Speaker Replacement, Speaker: stap 6, afbeelding 1 van 1
      • Unplug the speaker from the mother board by pulling horizontally.
      Vraag FixBot
      Voeg opmerking toe
    2. Apple IIc Speaker Replacement: stap 7, afbeelding 1 van 1
      • Heat the glue to loosen it, then wiggle the speaker up and out. Use the screwdriver to scrape off the remaining glue.
      • An easy way to heat the glue is by using a hair dryer on a low setting.
      • When heating the glue, do not use any high wattage device! This may burn or damage the chips or circuit board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Josiah
658 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-23, Maness Fall 2011 Lid van Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Leden
54 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 40
Altijd: 2,047
