Ga door naar hoofdinhoud
Apalus Digital Hair Straightening Brush Heating Element Replacement
Wat je nodig hebt
  1. Apalus Digital Hair Straightening Brush Heating Element Replacement, Heating Element: stap 1, afbeelding 1 van 1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Heating Element Replacement: stap 2, afbeelding 1 van 1
    • Turn comb over so the bristles are facing down.
    • Remove backside of the comb and place aside.
  3. Apalus Digital Hair Straightening Brush Heating Element Replacement: stap 3, afbeelding 1 van 1
    • Unplug the power cord from the connector inside of the brush.
  4. Apalus Digital Hair Straightening Brush Heating Element Replacement: stap 4, afbeelding 1 van 1
    • Remove the circuit board and heating element from the handle.
    • This will provide easy access to the necessary components.
  5. Apalus Digital Hair Straightening Brush Heating Element Replacement: stap 5, afbeelding 1 van 1
    • Remove the four 6mm Phillips #2 screws holding the heat shield onto the back side of the bristles.
  6. Apalus Digital Hair Straightening Brush Heating Element Replacement: stap 6, afbeelding 1 van 1
    • There are 4 solder points of the heating element located on the LCD side of the circuit board.
    • Desolder these four connections using a soldering iron.
    • Note which wires go to each of the connection points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Heating Element Replacement: stap 7, afbeelding 1 van 1
    • Solder the new heating element to the same connection points as they were removed from.
Conclusie
Aaron Brysch
231 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Harley Fall 2017 Lid van IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 2,189
