Ga door naar hoofdinhoud
Apalus Digital Hair Straightening Brush Buttons Replacement
Wat je nodig hebt
  1. Apalus Digital Hair Straightening Brush Buttons Replacement, Buttons on the side of the brush: stap 1, afbeelding 1 van 1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Buttons Replacement: stap 2, afbeelding 1 van 1
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush Buttons Replacement: stap 3, afbeelding 1 van 1
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush Buttons Replacement: stap 4, afbeelding 1 van 1
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush Buttons Replacement: stap 5, afbeelding 1 van 1
    • Locate the three buttons on the bottom side of the circuit board.
  6. Apalus Digital Hair Straightening Brush Buttons Replacement: stap 6, afbeelding 1 van 1
    • Each button is soldered in four places on the circuit board. Using the soldering tool, melt each of these four points and remove the dysfunctional buttons.
    • You may have to bend the dark red capacitor out of the way to reach the soldering points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Buttons Replacement: stap 7, afbeelding 1 van 1
    • Now that the dysfunctional buttons are removed, use a soldering tool and solder to install the new buttons on the circuit board.
    • Solder at the same four points as when previously melting these points to remove the buttons.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Aaron Brysch
231 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Harley Fall 2017 Lid van IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 668
