Ga door naar hoofdinhoud
Aoson R103 Speakers Replacement
Wat je nodig hebt
  1. Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: stap 1, afbeelding 1 van 3 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: stap 1, afbeelding 2 van 3 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: stap 1, afbeelding 3 van 3
    • Turn off the device using the power button.
    • Using fingernails/a pry tool, separate the back panel of the device. This may decent force as they are connected by push tabs.
    • Be careful not to drop the device when separating, this could cause permanent damage.
    • This will expose the motherboard of the device.
  2. Aoson R103 Speakers Replacement: stap 2, afbeelding 1 van 2 Aoson R103 Speakers Replacement: stap 2, afbeelding 2 van 2
    • Use your fingers to unclip the ribbon connecter and then pull the ribbon out of the connector.
    • This ribbon connects the power button and stops the device from turning on; allowing further procedure.
  3. Aoson R103 Speakers Replacement, Speakers: stap 3, afbeelding 1 van 3 Aoson R103 Speakers Replacement, Speakers: stap 3, afbeelding 2 van 3 Aoson R103 Speakers Replacement, Speakers: stap 3, afbeelding 3 van 3
    • The motherboard connections to the speaker are circled, they will be needed later.
    • The two speakers are circled in orange, they are attached to a plastic piece via a screw.
    • The 4.0mm long philips-head 00 screw will be disconnected at the Boxed area where the plastic disconnects.
    • Be careful not to disconnect the back ground wire when taking the plastic off.
  4. Aoson R103 Speakers Replacement: stap 4, afbeelding 1 van 2 Aoson R103 Speakers Replacement: stap 4, afbeelding 2 van 2
    • The box contains the four (4) soldering connections for the two speakers. Unsolder the old speakers and solder the new speakers in.
    • Be sure to match up the appropriately placed speaker to its correct positive or negative node. mixing these up could distort audio or fry the speakers.
    • Note: solder over a piece of paper where you can mark each node with a red or black marker to denote positive and negative nodes for the left or right speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Louis
208 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 153
