Inleiding
Is the speaker on your answering machine not working well? This is the guide for you!
Wat je nodig hebt
Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
Use a screwdriver to remove all four 11mm Phillips #0 screws.
Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
Use a screwdriver to remove the two 7mm Phillips #0 screws.
Solder your replacement speaker into the circuit. For assistance with soldering check out the iFixit Solder and Desolder Guide.
