Ga door naar hoofdinhoud
Answering Machine Speaker Replacement
Wat je nodig hebt
  1. Answering Machine Speaker Replacement, Base: stap 1, afbeelding 1 van 1
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Answering Machine Speaker Replacement: stap 2, afbeelding 1 van 2 Answering Machine Speaker Replacement: stap 2, afbeelding 2 van 2
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Answering Machine Speaker Replacement, Answering Machine Speaker: stap 3, afbeelding 1 van 2 Answering Machine Speaker Replacement, Answering Machine Speaker: stap 3, afbeelding 2 van 2
    • Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
    • Use a screwdriver to remove the two 7mm Phillips #0 screws.
  4. Answering Machine Speaker Replacement: stap 4, afbeelding 1 van 1
    • Finish speaker removal by cutting both the black and red wires.
  5. Answering Machine Speaker Replacement: stap 5, afbeelding 1 van 1
Conclusie
Troy Chester
66 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-3, Harley Fall 2016 Lid van IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 645
