Ga door naar hoofdinhoud
Anki Vector LCD Facial Display Replacement
Wat je nodig hebt
  1. Anki Vector LCD Facial Display Replacement, LCD Facial Display: stap 1, afbeelding 1 van 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: stap 1, afbeelding 2 van 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: stap 1, afbeelding 3 van 3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
  2. Anki Vector LCD Facial Display Replacement: stap 2, afbeelding 1 van 3 Anki Vector LCD Facial Display Replacement: stap 2, afbeelding 2 van 3 Anki Vector LCD Facial Display Replacement: stap 2, afbeelding 3 van 3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
  3. Anki Vector LCD Facial Display Replacement: stap 3, afbeelding 1 van 2 Anki Vector LCD Facial Display Replacement: stap 3, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
  4. Anki Vector LCD Facial Display Replacement: stap 4, afbeelding 1 van 2 Anki Vector LCD Facial Display Replacement: stap 4, afbeelding 2 van 2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
  5. Anki Vector LCD Facial Display Replacement: stap 5, afbeelding 1 van 3 Anki Vector LCD Facial Display Replacement: stap 5, afbeelding 2 van 3 Anki Vector LCD Facial Display Replacement: stap 5, afbeelding 3 van 3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Shay Takei
1.570 Reputatie
5 handleidingen geschreven
Cal Poly, Team S2-G6, Maness Spring 2019 Lid van Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Leden
10 handleidingen geschreven
26 opmerkingen
Any idea where to get the proper displays ?
Holger Brueckner - Antwoord
xenojin - Antwoord
This is great information, but where can I buy the display?
Jackie Fischvogt - Antwoord
yeah I can’t find it anywhere.
Joel Choi -
Does anyone have a line on display parts source?
warren williams - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 81
Altijd: 10,963
