Ga door naar hoofdinhoud
Anker Soundcore Space One Ear Pad Replacement
Wat je nodig hebt
    1. Anker Soundcore Space One Ear Pad Replacement, Ear Pads: stap 1, afbeelding 1 van 1
      • Flip over the device so the ear pads face up.
      • This replacement guide will only cover one of the ear pads. The same exact steps apply to both.
      Vraag FixBot
      Voeg opmerking toe
    2. Anker Soundcore Space One Ear Pad Replacement: stap 2, afbeelding 1 van 2 Anker Soundcore Space One Ear Pad Replacement: stap 2, afbeelding 2 van 2
      • Insert a spudger (plastic or metal) between the ear pad and the driver housing (the driver housing is the outside plastic part of ear cup).
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one.
      • Pry around the ear pad in a circular path until it fully releases.
      Vraag FixBot
      Voeg opmerking toe
    3. Anker Soundcore Space One Ear Pad Replacement: stap 3, afbeelding 1 van 1
      • Remove the ear pad from the driver housing.
      • The gray foam component shown is an additional protective component of the ear pad. You can remove it with your hands if needed, without any tools.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Malcolm Hewlett
433 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 2-3, Botvin Spring 2025 Lid van UMass Dartmouth, Team 2-3, Botvin Spring 2025
UMASSD-BOTVIN-S25S2G3
3 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 65
Afgelopen 30 dagen: 299
Altijd: 1,889
