Inleiding
If you want to replace the hinge pins on your Anker Soundcore Life Q20 headphones, follow this guide. The hinge pins are located where the ear cushions connect to the headband. They allow the ear cushions to rotate and lay flat against the headband in order to have a more compact design. They are also used to adjust the headphones for different head sizes.
They are not crucial to the main function of the headphones but are important for adjusting the headphones for travel and comfort.
Wat je nodig hebt
Using the Phillips #00 screwdriver, remove the two 10 mm screws from the connection between the band of the headphones and the base.
