Ga door naar hoofdinhoud
Anker 2.4G Wireless Mouse Sensor Replacement
Wat je nodig hebt
  1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: stap 1, afbeelding 1 van 1
    • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Sensor Replacement: stap 2, afbeelding 1 van 1
    • Using your Phillips screwdriver, remove the four screws.
  3. Anker 2.4G Wireless Mouse Sensor Replacement: stap 3, afbeelding 1 van 2 Anker 2.4G Wireless Mouse Sensor Replacement: stap 3, afbeelding 2 van 2
    • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
    • Make sure you are not using too much pressure, as you could warp the plastic.
  4. Anker 2.4G Wireless Mouse Sensor Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the wires from the white crimping headers.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse Sensor Replacement: stap 5, afbeelding 1 van 1
    • Remove the scroll wheel from the motherboard by pulling it to the left.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
  6. Anker 2.4G Wireless Mouse Sensor Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    • Gently lift the motherboard away from the plastic housing.
    • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
  7. Anker 2.4G Wireless Mouse Sensor Replacement: stap 7, afbeelding 1 van 1
    • Desolder the six wires holding the I.C. in place to complete the sensor change.
    • Replace the broken sensor with the new sensor and solder back in place.
    • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
Conclusie
Ryan
140 Reputatie
1 Handleiding geschreven
Cal Poly, Team 1-39, Maness Winter 2014 Lid van Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 7,794
