Ga door naar hoofdinhoud
AmazonBasics BTV1 Battery Replacement
Wat je nodig hebt
  1. AmazonBasics BTV1 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
    Vraag FixBot
    Voeg opmerking toe
  2. AmazonBasics BTV1 Battery Replacement: stap 2, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
    Vraag FixBot
    Voeg opmerking toe
  3. AmazonBasics BTV1 Battery Replacement: stap 3, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement: stap 3, afbeelding 2 van 2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
    Vraag FixBot
    Voeg opmerking toe
  4. AmazonBasics BTV1 Battery Replacement: stap 4, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement: stap 4, afbeelding 2 van 2
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. AmazonBasics BTV1 Battery Replacement: stap 5, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement: stap 5, afbeelding 2 van 2
    • Lift the motherboard off the face plate, exposing the battery.
    • Lift the battery out of its housing.
    • Use caution when using tools around the battery; batteries can be dangerous if punctured.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Chris Shannon
1.039 Reputatie
5 handleidingen geschreven
USF Tampa, Team 14-2, Lacy Spring 2016 Lid van USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Leden
10 handleidingen geschreven
8Gids Commentaar
donde consigo la bateria?
bnet_d72 - Antwoord Deel
Nice job, Chris! Thank you.
David Printz - Antwoord Deel
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - Antwoord Deel
Need information on where to get a replacement battery!
dan - Antwoord Deel
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 3,773
