Inleiding
The power switch is what turns the AmazonBasics on or off, as well as controlling the direction the shredder gears rotate. With age and extended use, the switch may sometimes break and require replacing.
Wat je nodig hebt
Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
Remove the two 8mm PH1 screws holding the IR sensor wire in place. This will give you more room to work with later on.
Remove the switch by unsoldering the 8 solder points on the motherboard.
