Ga door naar hoofdinhoud
AmazonBasics B00Q3KFX8U Motor Replacement
Wat je nodig hebt
    1. AmazonBasics B00Q3KFX8U Motor Replacement, Drive Gear: stap 1, afbeelding 1 van 1
      • Remove the shredder assembly from the paper scrap bin.
      Vraag FixBot
      Voeg opmerking toe
    2. AmazonBasics B00Q3KFX8U Motor Replacement: stap 2, afbeelding 1 van 1
      • Remove the two 10mm PH1 screws holding the small black panel in place.
      Vraag FixBot
      Voeg opmerking toe
    3. AmazonBasics B00Q3KFX8U Motor Replacement: stap 3, afbeelding 1 van 2 AmazonBasics B00Q3KFX8U Motor Replacement: stap 3, afbeelding 2 van 2
      • Remove the six 14mm PH1 screws holding the bottom cover in place.
      • Remove the cover by lifting straight upwards.
      • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
      Vraag FixBot
      Voeg opmerking toe
    4. AmazonBasics B00Q3KFX8U Motor Replacement: stap 4, afbeelding 1 van 1
      • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
      • The blades are sharp. Coming into contact with them may result in injury.
      Vraag FixBot
      Voeg opmerking toe
    5. AmazonBasics B00Q3KFX8U Motor Replacement: stap 5, afbeelding 1 van 2 AmazonBasics B00Q3KFX8U Motor Replacement: stap 5, afbeelding 2 van 2
      • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
      Vraag FixBot
      Voeg opmerking toe
    6. AmazonBasics B00Q3KFX8U Motor Replacement: stap 6, afbeelding 1 van 1
      • Use a metal spudger to pry the bracket from the main shredder assembly.
      • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
      Vraag FixBot
      Voeg opmerking toe
    7. AmazonBasics B00Q3KFX8U Motor Replacement: stap 7, afbeelding 1 van 2 AmazonBasics B00Q3KFX8U Motor Replacement: stap 7, afbeelding 2 van 2
      • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
      Vraag FixBot
      Voeg opmerking toe
    1. AmazonBasics B00Q3KFX8U Motor Replacement, Motor: stap 8, afbeelding 1 van 1
      • Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
      Vraag FixBot
      Voeg opmerking toe
    2. AmazonBasics B00Q3KFX8U Motor Replacement: stap 9, afbeelding 1 van 1
      • Disconnect the motor from the motherboard by either clipping the wires, or using a soldering iron to disconnect the wires directly at the board.
      • To reattach the motor, solder the wires back together, or to the motherboard depending on how you removed them.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
William Foley
548 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-3, Miles Spring 2016 Lid van UMass Dartmouth, Team 1-3, Miles Spring 2016
UMASSD-MILES-S16S1G3
2 Leden
1Gids Commentaar
Do you sell motor?
Binh - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 41
Altijd: 1,320
