Ga door naar hoofdinhoud
Amazon Fire TV Power Cord Port Replacement
Wat je nodig hebt
  1. Amazon Fire TV Power Cord Port Replacement, Motherboard: stap 1, afbeelding 1 van 3 Amazon Fire TV Power Cord Port Replacement, Motherboard: stap 1, afbeelding 2 van 3 Amazon Fire TV Power Cord Port Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Place the plastic opening tool in the space between the rubber and the plastic case of the device.
    • Apply pressure by pushing upward on the case.
    • Separate the bottom square rubber piece from the case using the plastic opening tool until all clips are detached.
  2. Amazon Fire TV Power Cord Port Replacement: stap 2, afbeelding 1 van 2 Amazon Fire TV Power Cord Port Replacement: stap 2, afbeelding 2 van 2
    • Locate the ten J#00 Phillips screws and remove them.
  3. Amazon Fire TV Power Cord Port Replacement: stap 3, afbeelding 1 van 3 Amazon Fire TV Power Cord Port Replacement: stap 3, afbeelding 2 van 3 Amazon Fire TV Power Cord Port Replacement: stap 3, afbeelding 3 van 3
    • Place your finger on the short edge of the motherboard and lift it to separate it from the plastic case.
  4. Amazon Fire TV Power Cord Port Replacement, Power Cord Port: stap 4, afbeelding 1 van 3 Amazon Fire TV Power Cord Port Replacement, Power Cord Port: stap 4, afbeelding 2 van 3 Amazon Fire TV Power Cord Port Replacement, Power Cord Port: stap 4, afbeelding 3 van 3
    • With the mother board back facing you locate the power cord port found on the far left end.
  5. Amazon Fire TV Power Cord Port Replacement: stap 5, afbeelding 1 van 3 Amazon Fire TV Power Cord Port Replacement: stap 5, afbeelding 2 van 3 Amazon Fire TV Power Cord Port Replacement: stap 5, afbeelding 3 van 3
    • Locate the four soldering joints for the power cord port found on the top side of the mother board.
    • Desolder the joints of the power cord port to release it from the motherboard.
    • Place the new power cord port into its original location and solder its joints.
    • Use the iFixit soldering and desoldering guide.
Conclusie
5 andere personen hebben deze handleiding voltooid.
jeffrey555
424 Reputatie
2 handleidingen geschreven
USF Tampa, Team 16-3, Wollert Fall 2015 Lid van USF Tampa, Team 16-3, Wollert Fall 2015
USFT-WOLLERT-F15S16G3
4 Leden
16 handleidingen geschreven
2 opmerkingen
Aonde compro essa fonte ? wagnerj957@gmail.com
wagnerjr1977 - Antwoord
Ola moro no Brasil minha fonte queimou aonde compro outra?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 2,766
