Ga door naar hoofdinhoud
Amazon Fire HD 8 12th Gen Camera Replacement
Wat je nodig hebt
    1. Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: stap 1, afbeelding 1 van 3 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: stap 1, afbeelding 2 van 3 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: stap 1, afbeelding 3 van 3
      • Remove the device from any electrical source and make sure it is powered off.
      • Put picks around the corner and move them along the edge to pry the case off.
      • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Fire HD 8 12th Gen Camera Replacement: stap 2, afbeelding 1 van 2 Amazon Fire HD 8 12th Gen Camera Replacement: stap 2, afbeelding 2 van 2
      • With the corners lifted, take the opening tool and pry each corner off.
      • Repeat this for the corner diagonal from the initial corner.
      • Once both corners are pried off, gently take the back case off the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Amazon Fire HD 8 12th Gen Camera Replacement, Camera: stap 3, afbeelding 1 van 2 Amazon Fire HD 8 12th Gen Camera Replacement, Camera: stap 3, afbeelding 2 van 2
      • Using the iFixit opening tool, disconnect the battery from the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Fire HD 8 12th Gen Camera Replacement: stap 4, afbeelding 1 van 3 Amazon Fire HD 8 12th Gen Camera Replacement: stap 4, afbeelding 2 van 3 Amazon Fire HD 8 12th Gen Camera Replacement: stap 4, afbeelding 3 van 3
      • Disconnect the camera from the motherboard by unplugging the orange wiring.
      • Heat the area of the back camera up loosening the glue holding it in place.
      • Be careful when using hot tools and removing hot parts.
      Vraag FixBot
      Voeg opmerking toe
    3. Amazon Fire HD 8 12th Gen Camera Replacement: stap 5, afbeelding 1 van 3 Amazon Fire HD 8 12th Gen Camera Replacement: stap 5, afbeelding 2 van 3 Amazon Fire HD 8 12th Gen Camera Replacement: stap 5, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Once disconnected from the motherboard and heated up, use tweezers to remove the old camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jaden Palmer
485 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 411
