Ga door naar hoofdinhoud
Amazon Fire HD 10 Battery Replacement
Wat je nodig hebt
    1. Amazon Fire HD 10 Battery Replacement, Screen: stap 1, afbeelding 1 van 3 Amazon Fire HD 10 Battery Replacement, Screen: stap 1, afbeelding 2 van 3 Amazon Fire HD 10 Battery Replacement, Screen: stap 1, afbeelding 3 van 3
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Fire HD 10 Battery Replacement: stap 2, afbeelding 1 van 1
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      Vraag FixBot
      Voeg opmerking toe
    3. Amazon Fire HD 10 Battery Replacement: stap 3, afbeelding 1 van 2 Amazon Fire HD 10 Battery Replacement: stap 3, afbeelding 2 van 2
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    4. Amazon Fire HD 10 Battery Replacement: stap 4, afbeelding 1 van 1
      • Remove the screen and digitizer from the case completely.
      Vraag FixBot
      Voeg opmerking toe
    1. Amazon Fire HD 10 Battery Replacement, Battery: stap 5, afbeelding 1 van 3 Amazon Fire HD 10 Battery Replacement, Battery: stap 5, afbeelding 2 van 3 Amazon Fire HD 10 Battery Replacement, Battery: stap 5, afbeelding 3 van 3
      • Locate the power cable that links the battery to the motherboard.
      • Carefully unplug the battery power cable to disconnect the battery from the motherboard.
      • The third image shows what it should look like with the battery power cable is disconnected.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Fire HD 10 Battery Replacement: stap 6, afbeelding 1 van 3 Amazon Fire HD 10 Battery Replacement: stap 6, afbeelding 2 van 3 Amazon Fire HD 10 Battery Replacement: stap 6, afbeelding 3 van 3
      • Begin by locating the double sided pull tape locations.
      • Do not lift on the battery when doing the following step. You will bend it. It is very pliable.
      • Pull the black soft tabs to release the tape's adhesion.
      • Make sure you pull the tabs slowly and continuously away from the case until the adhesive is completely out.
      • Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
      Vraag FixBot
      Voeg opmerking toe
    3. Amazon Fire HD 10 Battery Replacement: stap 7, afbeelding 1 van 3 Amazon Fire HD 10 Battery Replacement: stap 7, afbeelding 2 van 3 Amazon Fire HD 10 Battery Replacement: stap 7, afbeelding 3 van 3
      • Make sure all the adhesive is removed before trying to lift the battery from the case.
      • After the battery is totally free of any adhesion, simply lift the battery from the case.
      Vraag FixBot
      Voeg opmerking toe
    4. Amazon Fire HD 10 Battery Replacement: stap 8, afbeelding 1 van 3 Amazon Fire HD 10 Battery Replacement: stap 8, afbeelding 2 van 3 Amazon Fire HD 10 Battery Replacement: stap 8, afbeelding 3 van 3
      • Inspect battery for any leakage.
      • Please follow all U.S. regulations and laws when disposing or recycling the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
11 andere personen hebben deze handleiding voltooid.
Jaie Hillery
1.774 Reputatie
10 handleidingen geschreven
USF Tampa, Team 16-6, Blackwell Winter 2016 Lid van USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Leden
80 handleidingen geschreven
9Gids Commentaar
why is there so much empty space next to the battery?
echow2001 - Antwoord Deel
Big screen, little processor. The screen dictates the space, that’s why the battery has to be secured with adhesive.
ctgblue - Antwoord Deel
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
tyger.night - Antwoord Deel
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
How do you know if ita battery or charging port? Mine dont do anything whe. Its
Tech Reviews - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 60
Afgelopen 30 dagen: 218
Altijd: 52,579
