Ga door naar hoofdinhoud
Amazon Fire 5th Generation Speaker Replacement
Wat je nodig hebt
  1. Amazon Fire 5th Generation Speaker Replacement, Speaker: stap 1, afbeelding 1 van 2 Amazon Fire 5th Generation Speaker Replacement, Speaker: stap 1, afbeelding 2 van 2
    • Ensure that your device is turned off.
    • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
    • While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
    • Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
    • Then, remove the back cover from the device.
  2. Amazon Fire 5th Generation Speaker Replacement: stap 2, afbeelding 1 van 2 Amazon Fire 5th Generation Speaker Replacement: stap 2, afbeelding 2 van 2
    • Pry the speaker from the case using the iFixit Opening Tool.
    • Lift the speaker up from the device to remove the speaker wires from their groove in the case.
    • Be careful not to pull the speaker wires from the motherboard.
  3. Amazon Fire 5th Generation Speaker Replacement: stap 3, afbeelding 1 van 3 Amazon Fire 5th Generation Speaker Replacement: stap 3, afbeelding 2 van 3 Amazon Fire 5th Generation Speaker Replacement: stap 3, afbeelding 3 van 3
    • Desolder the speaker wires from the motherboard.
    • iFixit has a helpful guide explaining how to solder and desolder here: Hoe moet je (de-)solderen?
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Amber Bunch
1.391 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-2, Nance Spring 2016 Lid van USF Tampa, Team 1-2, Nance Spring 2016
USFT-NANCE-S16S1G2
3 Leden
13 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,379
