Ga door naar hoofdinhoud
Amazon Echo Show 15 Camera Replacement
Wat je nodig hebt
  1. Amazon Echo Show 15 Camera Replacement, Back Panel: stap 1, afbeelding 1 van 3 Amazon Echo Show 15 Camera Replacement, Back Panel: stap 1, afbeelding 2 van 3 Amazon Echo Show 15 Camera Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
    Vraag FixBot
    Voeg opmerking toe
  2. Amazon Echo Show 15 Camera Replacement: stap 2, afbeelding 1 van 3 Amazon Echo Show 15 Camera Replacement: stap 2, afbeelding 2 van 3 Amazon Echo Show 15 Camera Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Amazon Echo Show 15 Camera Replacement, Inner Black Panel: stap 3, afbeelding 1 van 3 Amazon Echo Show 15 Camera Replacement, Inner Black Panel: stap 3, afbeelding 2 van 3 Amazon Echo Show 15 Camera Replacement, Inner Black Panel: stap 3, afbeelding 3 van 3
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
    Vraag FixBot
    Voeg opmerking toe
  4. Amazon Echo Show 15 Camera Replacement, Camera: stap 4, afbeelding 1 van 3 Amazon Echo Show 15 Camera Replacement, Camera: stap 4, afbeelding 2 van 3 Amazon Echo Show 15 Camera Replacement, Camera: stap 4, afbeelding 3 van 3
    • Remove the small connector from the main device.
    • Disconnect the camera cord from the motherboard.
    • Pull the camera out of the main device.
    • The camera is connected to the main device with adhesive. You will need to use a bit more force to get it out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Paysen Hudson
208 Reputatie
2 handleidingen geschreven
Utah Tech University, Team 1-4, McMurrin Fall 2023 Lid van Utah Tech University, Team 1-4, McMurrin Fall 2023
UTAHTECH-MCMURRIN-F23S1G4
3 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 396
